drill the drains out to 4mm.
what makes you think d/shaft has been changed ? i've never heard of 1 failing.
whilst you are there , copaslip the 3 bolts on the slave .
I used a 3mm drill but I’ll go back and do them 4mm as suggested
Driveshaft had yellow paint marker code written on it as if it had came from a bike dismantlers (unless they are marked like that from the factory ?)
Thanks for the tip on the slave bolts , I’ll make sure I do it ;-)
