JJohn Welland
Can anyone tell me why my 2610 after down loading a route from map source to the gps, it will run ok untill i make a wrong turn, then i get the of route recalculating but on the screen it has the message "Calculation Error"
The unit does not recalculate and the message stays there untill OK is pressed.
The unit will then go to driving mode. Then i have to go to the route menue and press Resume Route, But it does not resume the route from the present position,
so you have to find your way back to the route before it continues with directions.
I should say that it does not happen with every route down loaded just some and the last time i had this trouble a couple of days later the unit packed up alltogether just as i had started a tour of Norway. I returned the unit to Garmin and i got a replacement unit. Can anyone help?
Cheers JJohn
Cheers JJohn
