yes
I have the aluminium remus freeride. As supplied it is LOUD, dont even think about removing the "baffle", what a joke that is. I made mine quieter using the baffle from an Akropovic silencer for a KTM. Sorry but I can't be more specific than that, my local tuner had it lying around his workshop. It was a tight interference fit in the end of the can - heat can with a torch and beat the insert into position with a copper hammer. No way it is ever going to come out.
Assuming you have the removeable insert with your silencer (and it is stainless, not Ti), you need to track down an 8" length of stainless tube the same diameter as the inside of the insert. Weld it to the front of the insert. Should give a similar effect to my Akro baffle.
