I've just bought this lead http://www.nippynormans.com/product...mtom-gps-into-the-bmw-harness-gar-canbuszu660 to make use of the spare plug in my wiring loom under the clocks for powering my Sat nav.
The supply I assumed would be switched with the ignition and I tested it with my multimeter and right enough it switched with the key but once nav connected to it when I turn the bike of nav stays powered like the feed is permanent.
Is this the case ?
Is this the case ?
