Center stand mounts
Shep
Shep of the Dessert
Lleyn Penninsular
Hi all
During a discussion with a mechanic about an intermittant ABS/brake warning light problem, he asked me to check the clearance between the rear wheel and the ground when on the centre stand?????
It seems that the mounting brackets for the stand on some bikes can distort, causing the rear brake pedal to move in relation to its switch causing some strange problems!
Might be worth a quick look at! (my rear wheel clears the ground by about 1")
Regards Shep
