alp
Yes I am that Bob, Who the heck were you?
Anyway, as I understand the problem.
I was told that there was not enough oil getting through to the clutch plates and as such the dry/dryish plates were sticking together - hence clutch drag. I believe that this happened on the early brick K series. The factory assembled the plates dry. The fix was to soak the plates overnight in oil. This was tried on my bike but failed to give a complete cure. Though it was a little better.
As I understand it, the replacement push rod was designed to allow more oil through the push rod bearings to the clutch plates. I was told that the push rod slides in a phosphor bronze tubes.
I saw the replacement rod.
It was about 100mm long and about 8mm in diameter
The bearing surfaces were of a greater diameter the overall rod and each bearing surface had 3 longitudinally groves ground into it to allow more oil through. The groves are shown in red on the diagram below. (The diagram is just a very quick knock up of what I remember and only approx relative proportions).
I was told that the old push rod had no groves, but I did not see the old one, so I don’t know if it was stepped.
At present my bike is better but it is not a complete cure. When I first got it, if you selected first, the bike would jump forward most of the time, but not always, sometimes it was perfect. It happened more when hot than cold. Maybe the oil spun off the plates when the engine was running making then dryer (?). Hence the not enough oil was getting through. If the push rod diameter was at the smaller end of the tolerance range more oil could get through, so not all bikes would have this problem.
SMB
Hi Bob, looks like we never end up at Ocean at the same time!
It's worrying that you were told and the push rod mod seems to confirm, that the theory is that there is too little oil getting to the clutch and yet BMW at Garmisch told me the opposite! I was told there was too much oil getting on the plates.
Hope mine gets fixed before another long tour which is scheduled for my bike at the end of July, I don't want the clutch drag causing problems in traffic like on the Garmisch tour.
