Has anyone found some decent clear tank pads for the GSA? I can buy some Eazi-Grip and cut it down, but it'll probably look a bit Heath Robinson, so I'd rather get some pre cut pads. Anyone found anything half decent?
Nutty, did you check nippys?Has anyone found some decent clear tank pads for the GSA? I can buy some Eazi-Grip and cut it down, but it'll probably look a bit Heath Robinson, so I'd rather get some pre cut pads. Anyone found anything half decent?
That's just pre-cut ventureshield type material and not applicable to the GSA .
What happened to the vinyl Rich !
I have some R&G ones fitted.......they don't look Heath Robinson, but neither do they exactly enhance the look..........but they do stop by trousers scratching the paint when off-road/crappy conditions, as find wet dirt and dry dust between legs and tank start impacting the paint pretty quickly. From a visual point of view they are definitely more function over form.....and have to get the placement right as they only cover a small patch, rather than the whole area.
I also use invisible patterns, perfect fit.
http://www.invisiblepatterns.co.uk/shop/BMW-R1200-GS-Adventurer-2008-2013.html
I like the film idea, but tank pads will be harder wearing. I'm surprised that there's no one out there doing clear tank pads for the gsa.![]()
It's that 3m stuff, how hard wearing do u need it! Not sure on the clear pads but that stuff is pretty good , i stuck it on my 2011 GSA on the metal sides and the tank pad area it was still looking new after 9k miles.
Are you finding the G S letter transfers have rub points where your knees go by any chance? Same here and although they are lacquered in they will soon look rough. I have fitted a robust clear film on mine exactly the same shape as the Wunderlich tank pads. How you ask? I got Bahnstormers to trace around a Wunderlich pad as a template. A couple of minutes with scissors and hey presto......
The film I got from Mott Motorcycles. £15 for three large sheets.
Yep, my Rukka trousers started to rub the transfers. Bit annoying, but I caught it early. Have you still got the template?
Check these near me http://www.privacytinting.co.uk/index.html
They do 3M venturesield kits for bikes, and if you let them do it, it'll be a 1st class job.
The owner has just bought a new TB and just had the kit put on......top job too. I saw it just after it had been done.![]()
but a tank kit is just about doable yourself with patience.
Not for me!![]()
