clearing fault codes
Bill
benfleet, essex
Hi,
I've been checking and adjusting myTPS and I was told that if it goes above a certain voltage a fault is logged in the module.
How do I clear the fault codes?
Don't know what bike you've got - but i'll have a guess.
Pull fuse 5, clears the motronic of fault storage. Don't forget to re-set the motronic memory of the TPS range after you've replaced the fuse.
Thanks Steptoe.
Its an 1150 Adventure.
<Don't forget to re-set the motronic memory of the TPS range after you've replaced the fuse.>
How do you do that?
You waggle the throttle a bit. Just wind it fully open and closed a few times after you put fuse 5 back in.
