How's this for odd??
On the recce for the fords run I got well and truly dug in a couple of times......on one ford where the entry point is 60 yrds upstream from the exit point, I got so deep I got off (leaving it running on high idle 'cos me exhaust was a good few inches underwater ROFL) and walked around it wondering how the heck I was going to pull her out, with the bike sitting on the sump bash plate on the river bottom.
Anyway, shortly after that particular ford, I lost my clutch action, but I could still pump it up to change.
I got some Dot4 fluid, and after a quick call to Tippytoes, discovered how to bleed an ADV (and what a top bit of design it is
The fluid was black and watery, slightly frothy and obviously fekked, So we bled it through until it ran clear again, but within 20 mins I'd lost it again.
On the actual fords run on Saturday, my glamourous assistant Timolgra and I bled the beasty at least 8-10 times, and the fluid looked the same each time.
The penultimate time though, it lasted a bit longer, then after the last bleed, it didn't go again.....getting me not only all the way back to ther Hotel, but also down to BHT's on Sunday then back home to Kent.......still with normal clutch action.
Tippytoes was scratching his head- aopparently the slave cylinder sits above the gearboox so it's not in a casing where it could get swamped in water, but obviously it will get wet.
It's a sealed system....there was no sign of ay leaking or actual loss of fluid, but evidently water was getting in.
So there you are Ladies an' Gentlemen........how the fekk did that happen???
