Mouse
I suffered the first serious problem of my GS ownership today! Basically the clutch stopped working ... I'd pull the lever and it would disengage for a couple of seconds, but then engage again, which made riding in traffic rather tricky.
To cut a long story short, I got recovered by BMW Assist, quite promptly, so no worries there.
Yesterday, the bike spent a short time "horizontal", if you get my drift
I'm wondering if I have got air into the clutch hydraulics.
So questions: Is it easy enough to bleed the clutch? I can see the bleed nipple at the back of the engine. I assume it's just like bleeding brakes? Secondly, what hydraulic fluid should I be using? The manual just says "mineral oil". Bike's a 1200 by the way.
I know I could get the dealer to sort this under warranty (presumably) but that would mean taking time off work to take the bike there, so I'll have a go myself if it's not a complicated job.
Thanks for any advice
I'm wondering if I have got air into the clutch hydraulics.So questions: Is it easy enough to bleed the clutch? I can see the bleed nipple at the back of the engine. I assume it's just like bleeding brakes? Secondly, what hydraulic fluid should I be using? The manual just says "mineral oil". Bike's a 1200 by the way.
