I've recently found I'm having to pull the clutch lever in as far as it'll go before the clutch completely disengages. During normal riding pulling it in this far is abnormal and hence I'm having gear change issues. I'm aware the typical distance before engage is about 3/4 to 1 inch.
The adjuster only had two turns left before it was at max, I did this and hasn't made enough difference.
Clutch plates were renewed at 25k (now at 47k). Fluid was down but not enough to have air in the pipe and I've since topped up to no effect.
Ideas?
Ideas?
