flowmaster
Hi all
I cant get my clutch to release.I've rebuilt the entire bike(not the engine and clutch.I got a replacement engine from Motorworks for my terrible looking paint corrosion) and am having trouble getting the clutch to release.I've replaced the copper washers and bled the system in the normal way.I've got pressure nearly all the way on my lever(or what feels like pressure) but the clutch doesn't release.There are still tiny bubbles floating up from the bottom of the reservoir but none come out the slave end when I bleed it.Is it the master cylinder?It was sat in a box for a good 6 months before going back on the bike.Seals knackered?Shouldn't I get any dissengagement of the clutch even if the master cylinder seal is not up to scratch.I'm also using a red vitam fluid from motorworks which they say is for clutches.Do I need to use the proper V10 fluid.
Is the clutch push rod the same size from my GS04 to a GSA 07
many thanks
many thanks
