Soldering required? I also have none of those types of tools and experience (yet)Don’t let the working put you off. They’re easy to DIY.
I used solder free connectors, so just a bit of heat and wire strippers.
Interesting - I must look into some videos that show this. Would love to fit a pair.I used solder free connectors, so just a bit of heat and wire strippers.
Yes please!I did a video review of the D07 Pro’s if you’d like a link? I show how I wired it up in that video, I’m not an expert when it comes to wiring
Yes please!
Oh no joke - you're the stammering biker? Awesome hahaThe Ultimate Upgrade? CoLight D07 Pro Lights on the R1300GS
So the one thing I’ve learnt since doing this video is that not every circuit needs the earth wire being used, only one circuit does which cuts down on the mess of wiring a bit
I've been watching your video on how to do the B6 light as I have one coming!
I'm about to fit the same, 4 circuits with the amber doubling up as indicators. To be honest I have no idea how to wire this up, if at all possible would you drop me a sketch please ? My assumption is 2 plugs used per side , one being just for the amber & the other for the main & dip ? Or are they all wired into one plug(per side) and set up in the EzCanHad the 1300 gsa for about a month now - and straight away I missed the old christmas tree look of the 1250gsa that I traded in.
Went aux lights shopping - and whilst I love the look of motolights (bit less so the Denali d7pro), a thousand quid all in was a bit of a stretch after just paying for the bike.
Stumbled on the CoLight D09 pro - looks a lot like the motolight, has the amber ring round the outside & seperate cricuits for diffuse low beam / focussed high beam. A triple circuit light.
Bought the hex ezcan to control it all (£200) and bought the colight D09 pro lights (£115) with denali brackets (£80) - so all in for £400.
Taken me a few days to fit, spending an hour, then overnight to figure out next steps etc - but with everything delivered on Wednesday this week, it's now Saturday & everything is done.
Thoughts?
Fitting is simple, but takes longer than you think. Had to take apart most of the back end of the bike to fit the ezcan - nothing difficult - just took an hour or so.
The lights same story - the colights come with a harness & waterproof cables - you just cut off the primary wire to each light & then make up new ends to connect to the ezcan. I mounted on the crashbars, and wire routing was not the menace I was expecting - nice easy route through with existing wiring bundle, pops out through a hole where the seat adjusters are at the base of the tank.
Configured as Amber ring DRLs (on all the time the engine is on), doubling up as indicators. Diffuse beam & high beam aligned with the main lights on the bike. This does use all 4 hex ezcan circuits, but I have no immediate plans to add anything else, so all good.
Fit & finish of the colights seems identical to the motolights my pal has - and with the ezcan you have full individual control of all 3 functions - brilliant.
They are incredibly bright at full whack - absolutely love them.
Other than perhaps half an hour less hassle with the denalis / motolights when fitting, I see no difference at all.
Whilst £400 isn't cheap, it feels a lot better than £1000! 100% recommend these to anyone thinking of adding aux lights.
Any advice appreciated, I can't find any YouTube info on the actual wiring up the plugs.
Thanks, Mark
Brilliant , I'll keep a look out, much appreciatedMy install video will be out soon showing how to do this
Brilliant , I'll keep a look out, much appreciated![]()
sorry, link won't open
Strange it works for me, I'll link the full video when it's out on Monday but I've done some wiring diagrams for the 3 different ways I'd potentially wire it up (my opinion entirely). I've gone with the 4 channel setup as I currently don't have anything else running off the EzCan. One thing that helped simplify it was finding out the earth wire doesn't need to go to ALL of the EzCan channels, just one which made the whole process much easier.sorry, link won't open
Thank you so much, that's perfect and makes perfect sense to me now. Lights are due today so looking forward to getting it all sorted.Strange it works for me, I'll link the full video when it's out on Monday but I've done some wiring diagrams for the 3 different ways I'd potentially wire it up (my opinion entirely). I've gone with the 4 channel setup as I currently don't have anything else running off the EzCan. One thing that helped simplify it was finding out the earth wire doesn't need to go to ALL of the EzCan channels, just one which made the whole process much easier.
Please bear in mind I'm not an auto electrician nor am I a wiring diagram expert haha
That is a great description of the different ways to wire them up. Only wish you'd done it before I fitted mine!Strange it works for me, I'll link the full video when it's out on Monday but I've done some wiring diagrams for the 3 different ways I'd potentially wire it up (my opinion entirely). I've gone with the 4 channel setup as I currently don't have anything else running off the EzCan. One thing that helped simplify it was finding out the earth wire doesn't need to go to ALL of the EzCan channels, just one which made the whole process much easier.
One of, if not the best how to clips on the D09 pro. The wiring and set up is brilliant.Finally got my video out, apologies its a bit long and waffly, I filmed it in chunks over about 6 weeks as life has been a bit upside down so the video doesn't flow quite as well as I'd have hoped.
Sorry for being thick, but I can't work out what you actually purchasedAdded some pics - but if I'm honest, I think the actual value here is nothing to do with pics to look at.
The value is that I'm a materials scientist (not an influencer, not a youtuber, not a dealer). I don't sell these things, or have any interest in anyone else buying them. But I am super fussy, and completely understand what quality looks & feels like. That's my day job.
I've compared these colight d09 pro lights directly in the real world with my own previous Denail d7 lights (non pro), and my pal's brand new motolights. In real life.
My final thoughts are that I see no difference in quality of materials (none - these are 100% up the physical build of the premium brands), and light output is also much the same (I didn't measure lumens - but they are all idiot levels of brightness).
Just like the motolights, I think the amber ring DRL isn;t really bright enough to be anything other than a 'pretty gimmick' TBH - I will run the DRL as amber ring + low beam (as seen in photo 4). The amber ring is virtually an exact match for brightness to the handguard indicators - likely what they were aiming for when designing these. But to my eye - it's just not enough to stand out as a daytime running light. My mate (on a multistrada v4s) feels the exact same about the motolight DRL - just not bright enough during the daytime.
All features / multiple brightness / strobing with horns etc is determined by the hex ezcan - so the colights can do all the fancy stuff.
Amber ring is seperately controllable / in low beam only the bottm 4 LEDS light up with diffuse spread / high beam you get the top 4 TIR LEDS, plus a central projector.
I think the main step up is the fact you have 3x seperate circuits - so you can make your own mind up about low beam / high beam / DRL / indicators etc - I think the motolight is the only other light out there that gives this flexibility.
There is always that question mark about reliability I guess - they are Chinesium. But, I'm pretty certain that the working parts of every single premium light out there is also Chinesium, and colight has been selling aux lights for cars & bikes 10+ years with a decent reputation & I cannot find anyone complaining about failures - so I'm happy enough.
At this point I just don't see what you get for the extra money. Light pods alone these are £115 delivered. The Denali's something like £700, same for the motolights. All will need brackets & a controller - so that's moot.
So - I've taken the chance on them, you can make your own choices
They are fantastic IMHO.
