Stewart H
My last couple of tanks of juice have yielded around 30 MPG
This seems a lot for a completely standard 1100. I have hooked up my mulitimeter to the diagnostic plug and everything is working according to the fault codes. I cannot get the CO below 2.5%, bike starts and runs okay apart from blubbering like the choke is on, back of bike is sooty, I measured the resistance of the injectors at 15.9 ohms, TPS is at 0.385 valves are spot on, balance is good, air filter is clean, brakes are not dragging, oil and air temp sensors swapped, no difference, running out of ideas.
Stewart
Stewart
.joking apart mate have you tried lowering the tps setting and taking another co2 reading?i,m under the impression when the tps setting is lowered the co2 reading drops.but then i might be just talking a load of s--t.who knows
