she can come and have a go on my terra![]()
Too late
I think she's purchased now
I thought the Terra was a similar weight & height to the Dakar - is it not?
Too late
I have an F650 and rode an XCountry a couple of weeks ago .......
I saw you come back after that ride, your smile said it all
Mines 159kg give or take a wet filling mind you you can't compare these 2 different bikes completely
Even so, I do like it....let's see if Ange does
Well the decision was made but she's shown alarming disinterest so far....so I took it out
the dive on braking was a bit alarming at first.
.... the dive on braking was a bit alarming at first.
Can't possibly be any worse than a standard Dakar.![]()
Looked up the spec sheet on the Husky website and it gives the Terra @ 185kg kerbweight, with a 90% full tank of fuel
So more Dakar porky weight range, than a G650X![]()
http://www.totalmotorcycle.com/motorcycles/2013models/2013-Husqvarna-TR650Terra.htm
166- standard exhaust and other bits 159 dry
Have a look under the false tank. I've mounted an autocom, amplirider etc in the middle and on the left side tucked in a Kenwood radio for bike to bike. Not spacious but it works.
Thanks yes, I'd planned to fix one therebut may just go for a Sena/Scala headset instead.
... the Scala headsets are a much simpler set up, work well (up to 400m) and take up no space on the bike![]()
Initial reactions, pro's as expected ...... cons mainly expected:
Not as 'planted' as Dakar
Prefer Dakar for Motorway.
Unstable in side wind.
Generally though, more confidence inspiring which is what it's about so get's the
