DIY Tyre changing in field
Yup, it also helps if you unscrew and remove the valve core as then what little air you have can blast in quicker and hopefully get the initial seal.
always done that, but forecourt garage pumps dont have enough reserve tank air to wham up yer tire to seat the edges on the rim:blast
good idea with ratchet strap, stepers:thumb2
If there is another bike with you, place the wheel flat on the deck put the side stand down on the tyre against the rim and rock the bike down while sitting on it.
