argee
If you line up the yellow or green dot on the tyre sidewall with the valve a bike tyre shouldnt need balancing....apparently
If you line up the yellow or green dot on the tyre sidewall with the valve a bike tyre shouldnt need balancing....apparently![]()
I agree with argeeIf you line up the yellow or green dot on the tyre sidewall with the valve a bike tyre shouldnt need balancing....apparently![]()
Also using that balancer would you then buy wheel weights and stick on? It's a nightmare subject
Did you read the posts about using puncture repair gunk or dynabeads? There is also an EXCELLENT point regarding having balanced wheels and tyres then skidding the rear wheel (non ABS) creating a flat spot! This will instantly throw the fixed balance out where as the dynamic balancing media of dyna beads or gunk would instantly compensate for this.
BTW... what tyres are you fitting? I've read all the bollox about all sorts of tyres and comparisons but lets face it... It would appear that unless you intend riding on nothing but tarmac people use the Tourance or TKC?
Today I rode down the lane outside my house which was lose gravel, mud, pot holes, ice and a little slope with turns... It's far from what I would call off roading but the Tourance tyres felt like riding on water??? No feed back, lose washy and didnt give any confidence!? So whats all the fuss about?
If the Tourance is the closest compromise between road and off-road then TKC's are the only way forwards!!!
I'm pretty sure alot of the GS experienced guys will tell you that you will need some format of adapter to use that style balancer with the GS rear wheels? I know you can buy the adapters for sure...
The front wheel could easily be balanced in the bike with the calipers flipped up to prevent friction. The rear wheel is a different story I fear... Also using that balancer would you then buy wheel weights and stick on? It's a nightmare subject![]()
and all you need is some good tyre levers, tyre soap and some rim protectors or as someone else said reinforced garden hose which you just slit and put over the rim edge.
wont these beads "shotblast" the inside of the rim and the tyre?
after watching the video its a question i pondered....
why dont you just go to trevs tyres in the bont..... he's cheap as anybody does a good job, likes a chat and he's really close to where you live?
