hutchy
Took the FD off tonight 2004 1150gsa 41k
I checked the rear wheel at the 3-9 and the 6-12 for movement
Very tiny amount at the 3-9 but about 1mm at the 6-12
Re torqued the paralever bearing no change to the movement
Then I did my usual stunt and pulled the FD (only way to learn if your self teaching!)
Anyways no issues removing FD
But I'm sure the drive shaft attached to the Bevel box is meant to be attached via a snap ring circling call it what you want when the FD is removed, and then you pop it off
Well mine wasn't it remained attached to the main drive shaft and I found this little issue
Look closer, the snap ring is bent out of its recess
And a small nick on the other side taken out of it too
Anyone know what caused it and what the fix is?
The rest of the FD looked grand
And why do I have play at 6-12 am I missing something in the searches I have done?
Thanks all
H
Thanks all
H
