This ?
Indeed.
This ?
I don't know enough to comment either way, but I'll ask a question. Does the shaft slide in and out of the female portion in normal operation?
Surely if the shaft is sliding in and out of the female section everytime the bike is ridden then it isn't still long enough to sieze in it? Or am I being too logical here, I thought that for something to sieze together it has to be left static for a long time for the rust to act and fuse the two elements together.
Like any topic, folk can read the post and decide for themselves. I don’t think anyone is scaremongering. There is a problem though, any rationale person can see that. Water finds it way into the bellows and causes corrosion and seizing of parts that are meant to move freely. That means they have failed in the task they were designed to do. I’m not suggesting for one minute that your back wheel will fall off whilst riding, but if the splines are seized the back end of the gearbox is going to be receiving loads it wasn’t designed to. Over time this will no doubt have a detrimental effect on it. A bit of preventative maintenance will stop it happening. Doesn’t need doing every week, but once a year the FD can be dropped and checked. Like you, I have owned and ridden circa 15 GSs, both chain and shaft driven. Chain drives require a bit of fettling to keep them sweet, as do shaft drives. It what Sunday afternoons are all about!
OK.
So tell me, what exactly will happen if I dont strip and grease mt shaft splines annually ?
Who knows?! Why would you wait to find out though??? I think its you making more out of this than those posting their experiences to be honest.
ok, what then ?
Your exhaust manifold is designed to slide in and out is it? Must be the vario manifold version!! Your flap has probably seized downstream though so I would be having a look at that if I was you...There's a bolt on one side of my exhaust manifold. I think it may be seized. I think, that if i undo all of the bolts on my bike, just to check to see if they have seized, and grease them . My bike will run better, in some way, probably. Then post on here, that if you dont undo a seized bolt, The bike is going to explode, well, not explode, implode, errrr well, not that either, maybe the indicator will fall off, Oh you know, something will disintegrate because of it, probably.
That’s up to you, its not for me to tell you what you should do. If you have never had an issue then do nothing. All I’m saying is that for those that feel competent to check, why not? If nothing else you get to know your bike a bit better and a sense of achieving something perhaps. Not here to argue with you, I just can’t see how you can dismiss it as a non issue when clearly people have had/have problems.
