- Joined
- Jul 23, 2004
- Messages
- 2,375
- Reaction score
- 126
Initially ran my 02 1150GSA to low fuel levels. Last time parked up facing down on a slope and was very difficult to start afterwards. And since then difficult every time, especially when cold. Thought maybe sediment had got past the filter and blocking the injectors (1200 type installed).
So, replaced fuel strainer and filter in tank. Removed injectors and cleaned, spun engine over and fuel spurted out of open lines OK.
New air filter and plugs put in but, still the same starting problem. Ignition on and I can hear the fuel pump prime.
No CAT but Y-piece and open Z-technik exhaust.
When running and riding, there are no obvious faults showing up and sounds normal. But still running rich.
I get a good spark and fuel getting through to the heads so, what next!
Thinking the O2 sensor is carboned up and I can see soot at the outlet of exhaust.
Could the now dirty O2 sensor be the culprit?
Sending the wrong signal to the ECU.
Once tank is low will remove and detach sensor and wire connection for a clean,
Any aftermarket O2 sensors to consider buying for my bike model from a motor factors?
Patria o Muerte
Patria o Muerte
