DWA???
newman7096
Tamworth
I've recently aquired a 1200GS. Its a 55 plate 05 model and when I turn the ignition on it goes through the various checks, bulbs, EWS, etc but then it displays DWS and a long battery type symbol.
What is DWS? Can't remember seeing that one on my last 05 GS?:confused:
+ 1 And you will have the added benefit of knowing how to start your bike properly in cold weather; how long you can leave the battery without charging etc. In fact, you will know all about your bike .............. brilliant :thumb2
Available on line here for the '08 model.
http://www.bmw-motorrad.dk/dk/da/index.html
Then follow for model (Motorcykler) and Downloads for manual and the DWA manual
To put you out of your misery it's German for alarm
:blast Oh ok....it's the DWA ....Diebstahl Warn Anlage...Theft warning system (from what I can see by just typing it into Google anyway) ;)
I'd guess ('cos I can't be bothered to read the google results ;) ) that your alarm has been triggered in your absence and it's telling you that. :nenau
I can find no mention of it in the manual I've got!
Its not a problems but I wonder what it is?
It's in the Rider's Manual, at the start of the 06 version at least.
Status indicators section
Warnings, overview Mode of overview sub-section
You may have a yellow warning triangle - there seems to be two versions of the warning (one with triangle and one without) depending on the fault - and DWA! (BuMW's exclamation mark, not mine)
The answer is, on the same page.
(i) The Anti-theft alarm battery is weak
or
(ii) The Anti-theft alarm battery is flat
The same sub-section (four pages later) explains the cause and the solution.
DWS, DWA, EWS all in the name of progress:thumb
It would seem you are right :thumb2 Though I'm sure you didn't quite mean it that way ;)
It's a warning that the anti-theft device needs attention. Quite useful, perhaps?
Who knows, it may just stop someone walking out the door and finding their bike gone.
Though, equally useful might be a display that lit up, saying "RTFM" from time to time.:D :beerjug:
Ah ha! I asked the BMW dealer to turn it off so that whats probably what its telling me...that its off. No warning triangles or anything just an image of an empty battery.
Checked my manual again and its definately not in there!
That's because there is a separate supplement to the manual if you have an alarm fitted old chap... Must have got lost between owners? :)
So the symbol showing an empty battery, would that be telling me I need a new battery in the fob?
Odd, as I have a OEM BuMW alarm fitted and the EWA! warning is in the bog standard Owners' Manual.
There is no mention of EWA! in the separate handbook for the alarm, which relates only to the operation of the alarm's remote fob.
Funny old world.
Have you downloaded the Alarm Manual from the address I took the time to look up for you or not ? :aidan
From your link the EWA! warning explanation seems to be in the Rider's Manual, still.
It makes sense for it to be there as the warning flashes up on the bike's instruments and relates to the alarm's in built battery. :D Just like it is on the earlier models. Not the place some might think to look perhaps? :augie :D
Good find for the on-line manuals by the way, even if one has to fight through the Danish. Shame the UK site doesn't have the same.
