Early paralever 80GS rear brake switch cable routing ??
Not open for further replies.
Grantiii
West Yorkshire
Hopefully one of you nice forum members could help me!!
After major strip, the nice bit.....
Attaching everything to nice powder coated frame.
Including overhauled final drive & gearbox + other pretty vapour blasted parts.....All thanks to the Great Mikeyboy 👍
Just re-bushed rear brake lever, refit & set up the micro switch.
Now, where does the cable exit & somehow not foul the paralever pivot area, on it's way up the frame.
There is a hole below switch & a slot next to where brake cable attaches, where cable is in pic !
No obvious route from either. A pic attached to explain. Thanks.... Ian
Thanks Alot Mike.....
I thought that may be the case....its just pretty damn poor, with proximity of paralever pivot point. Happen I can bolt a wee 'P' clip using that hole.
On rear bumper there is a plastic clip which secures cable with a cable tie are these clips available ?
The one on the rear mudguard is simply a zip tie through a plastic washer
