ECU Location.
Thanks Mike,
The tanks coming off next week to replace fuel pump. :thumb2
Be very careful undoing the nuts on the fuel pump plate - use loads of penetrating oil (not WD40) and clean the treads with a wire brush before even attempting undoing them. If you shear one off you may be lucky and get it to seal, but two in line will mean a new tank or finding someone daft enough to weld/braze new studs on...
The ECU box is silicon sealed and is a bugger to prise apart so be careful and take your time.
Thanks Mike, I've already been told about that and have some penetrating oil and wire brush at the ready
