electrical connectors
donkeydoo
south east
Any of you Harley guys know what connector this is, I want to get a male to add a sat nav...this one I believe is a spare hot behind the headlight?
Cheers all
Possibly for heated handlebars, it may well be the prewired connection from the throttle side.
I could be hopelessly wrong but if it is you should be able to chase it to the throttle side of your bars
If its the same as moto guzzi you can use it as the live switched feed for the sat nav. There is a BMW male connector available that should fit. About £16 if memory serves me correctly.
Cheers. Ron
All sorted, thank you, I tried and tried to get the sat nav to work from this feed to no avail, may have a break in the wire somewhere or not be fully wired up. So just piggy backed off the pilot light...cheers all
