Ok guys, my bike(R1150GS) was running fine...but I heard the ticking noise from the right Throttle body and decided to go for Dan's kit. Kit arrived and both TB's refurbished...no prob. While I was at it i gave a look to the valves to see if they were correctly set. No prob..the valves only needed a very slight setting(Just to get them perfect!) Made the Throttle position sensor perfectly to .36v! Reset the motroninc, turned the throttle 3 times.... Started the bike.Ok bike started, not really happy with the idling, but it is still cold! not even 1 bar on the display and the right header is red hot???!!!??! Bike is switched off immediately.
So I guess it is lack of fuel that is causing this....Should I open the air mix and then set it slowly or what am I missing....The bike seems to run on both cylinders but is too Lean????
Any help would be greatly appreciated!!!
