And 'old' post indeed, but appearently still valid....
Seems like OP is running low on options.
As for the BMS not responding, there are really only two options:
1: Power to BMS interrupted for some reason.
2: BMS is busted.
It's hard to pick the correct option from internet.
However, OP asked in one of the earlier posts if there is an easy way to confirm whether the BMS is working or not.
There is no easy solution beyond what has been suggested allready. But I will suggest what at best may be regarded as a longshot:
Take a look at this picture of part of the R1200 GS Schematics.
First a bit of educated guesswork:
Main power to the BMS is fed from a direct connection to the battery. But in order to not drain the battery, there must be a built in relay that is controlled with power from the ignition switch. I assume this relay will connect as soon as igniton is turned on, regardless of a faulty ECU inside the BMS, as the ECU will only be powered after the relay has been activated.
Looking at the schematics, for some reason that I am not able to explaine, the BMS feeds the right signal light switch, controlled from the right multifunction switch on the right handlebar. The left handlebar multifunction switch is controlled exlusively from the ZFE (The only explanation I may think of is the German vehicles having a feature where the left signal indicator may be turned on even when the vehicle has been stopped as some sort of emergency light).
Anyway, if we luck out, this power, being a dumb 5V signal may be working directly from the BMS voltage regulator powered via the internal relay, even if the internal ECU is busted.
Hence, by turning on ignition and activate the RH turnsignal and operating the Signal Cancel switch as well, a functioning RH turnsignal will only be working if all the powerleads to the BMS are working, thus this will show that the BMS is powered, yet not working.
On the other hand, if the RH signal does not work does not necessarely mean that the BMS is busted, since my hypothese is an assumption only, thus further search for faults is required...
