Deleted account 200502001
- Joined
- Mar 10, 2014
- Messages
- 10
- Reaction score
- 5
bear i sense there could be some confusion here,the end of the gear lever tip will rotate once the torx bolt is loosened.the whole gearlever can be rotated on the splines either up or down but you must remove the torx bolt to allow this.
Thanks, I've done it now.
Before...
After...
Now for a test ride
Im surprised they don't allow for further adjustment. If its not adjusted enough I'll consider moving the lever a little. Thanks
