Final Drive Failure Register
bisbee
VIGILUM
Newark Notts
I have had mine fail at 13000 miles so let's see how many more of you have had a final drive failure please and at what mileage :nenau
yeah i think so
Yeah i think there's a point , I'd like to have some idea of when i should be paying extra special attention to the fd...could do with the age of bike and the type of usage its been subjected to , maybe a pattern will emerge.
I think you'll find there is no pattern as the failures seem to be totally random and you will be needlessly worrying about nothing. If you follow the threads on fd's there doesn't seem to be much connection.
For comparison, my 06 GSA has done 60k, been used regularly on and off road, very hot +44 degress and very cold climates - 12 degrees, altitude to + 12,200ft and - 284ft, commuted and long hard days on motorway and is ridden all year round. The fd is as good as new with no movement and you would think mine would be a candidate for failure.
Talking to my dealer today and they really don't know what the problem is apart from perhaps a bad batch of bearings.
Think yourself lucky you don't ride an RT because they go for a pastime by all accounts:eek:
06 GSA used everyday commuting to and from work.
Two up fully loaded (read probably over loaded),touring europe and GB.
1st F/D 12000 Tourance tyres
2nd F/D 21000 Tourance & Conti Road attacks
3rd F/d 28000 rebuilt by self, 32000 all ok. Conti road attacks.
4th F/D on bench ready to be rebuilt, working on the theory if you've got one you'll never need it.:thumb2
05 GS... 30000 miles original F/D, FPC and battery... just had one dip head lamp bulb blow last year... just lovin it super bike...
***one dip head lamp bulb blow last year***
I hope you rang your dealer to complain about the sh1te mbw bike they sold to you:augie:D
First failure at 12500 miles.
Going in for checking this week at 20000 miles. Looking suspect, lots of play. Extended warranty will cover it if necessary.
Final drive problems
Hi you guys,
I don't know if this question has been asked before, if it has, I'd better apologise now for not reading the answer !!
What's the rate of replacements on other big Boxer twins ? I'm thinking the 1200RT for example, the local police use them down here in Cornwall, huge mileages etc regularly covered and I've not heard too much on specific problems with the other models. But there again, this is a GS flavoured website.
In fact I think I remember reading somewhere that a popular mod is to retro fit a unit from a RT, but is this worth it ?
Anyone able to answer ?
BMW should advise cause
I came across a good article written in a U.S. forum, sadly cannot find it again. The gist of the article was that the FD problem is pot luck relating to the way it is assembled to start with. I would agree with that theory but take it slightly further. BMW have plenty of design experience in drive units and their repective bearing loads not to make a fundamental mistake. Also were this to be a design fault then in my opinion it would be a lot less random. I would also not consider a bad batch of bearings, that just does not happen from any reputable bearing manufacturer these days. Much more likely is either incorrect assembly or incorrect machining or a combination of both. There is no doubt that BMW have a serious FD issue here and to date have chosen to do little to alleviate owners fears of impending failure. If I go back to the twin shock boxer range from the eighties to the date that they stopped production I am not aware of ever hearing of a final drive failure. There is a need for owners to collate the data on this and make a case against BMW that would encourage them to do a subsidised replacement until a resolution is found. I think also that it is about time that BMW opened up and advised the cause for these random failures, that certainly would give owners an ease of mind compared to the silence at present.
2006 R1200GS Adv
1st FD failure circa 18,000.
2nd FD failure circa 36,000.
Not had a problem since, now at 100,000.
