final drive leak
elevensies
yorkshire
just got in from Cadwell, thankfully it was raining so taking it easy, else i could have slid into the hedgerow somewhere,
riding back, bike felt squirmy from the back end and rear brake not brill, and a rubbing noise appeared from what i thought was the rear of the bike (like a pad out of line or warped disc?)
45 miles later, stopped outside my house gates to open them, and pouring out from the final drive housing onto my tyre was grey oil.
ok so what work am i faced with please? or is this heading to a garage for the repair? cost etc
Rear big bearing and in your case seal as well, not major treat it as a new chain and sprocket..:augie
have
a look here, reckon you'll be faced with a similar scenario
thanks for that Hops, i dont think i will be doing the job, i just dont have time at the moment as im heading back to work.
cheers though:thumb2
got bmw picking bike up tomorrow, taking it to Rainbow hopefully, so am i looking at a big bill???
i luckily took out extended warranty last yr so again hopefully the pick up and drop off is free.
That is the best kind of breakdown, with the fault manifesting itself as you pull up to your gate :thumb2 I would be interested to know how much the dealers charge for the big bearing replacement.
Stewart
Stewart, i looks like it was leaking in the ride back from cadwell, as my panniers were covered in oil, but im guessing the big drop was outside my place.
will let you know when i get the call.
if i could have got the bike somewhere else, or had the time to strip it and have a go myself i would have done but im kinda stuck as i have a euro trip booked in 8 days:nenau
i will loose out as i have paid for the trip already, then this cost, im pretty fecked......
or i just go on me old r60, with leaking carbs:confused:
They all go eventually, be thankful yours went at home. Mine failed catastrophically with no prior wanring in the middle of a 7km long italian tunnel. :blast
It went again 7000 miles later at home. Still loved that bike (sold it for a sidecar outfit :D)
Cost was about £150 for the repair to a loose drive box at Allan Jefferies BMW.
thanks for that Guzzi,
i had heard that once they go, they nearly always carry on ''going''
maybe a bike re-think, :rolleyes:
If the cause of the failure was incorrect shimming from the factory, and the shimming issue isn't corrected when the new bearing is fitted, then of course it will tend to fail again. If the replacement is fitted properly, though, there's no reason to expect it to 'keep going' unless you mean "keep going every 100,000 miles or so" in which case.........it lasts longer than a chain and sprockets :)
after the fiasco of the final drive bearing and oil seal going, and then having Rainbow repair it, went to Europe and the blasted thing started weeping like a school kid who sweets had been pinched.
3 weeks ago rainbow collected bike and had to replace the whole rear end:thumb2
apparently when the bearing failed it scored the bearing housing enough for it to leak again:mad:
so got bike back yesterday and its got a new shiny rear drive.
sterling effort rainbow, although the price:eek:
glad i didnt pay:beerjug: as they held responsibility:JB
Cost
Hi, Elevensies,
How much did Rainbow charge for the first bearing replacement?
Mine has got 35,000 on it so I am trying to decide whether to do the work myself or book it in somewhere.
