i'm sure steptoe did one of these, but i am having some difficulty finding it. anyone got a link?
ta
ta
maybe i'm mistaken?
there's a gap waiting to be filled then![]()
saw that one, but it seems more of a roadside fix guide?
i was looking for something that explained better how to get behind the bearing to get it off, and more detail on shimming.
Bearings are high presion tings so should not need changing if correct to start with
not actually sure how a cutaway cover is used. but if you are checking the distance between the bearing and the modded cover somehow, that would rely on the two covers being machined identically wouldn't it?
The covers vary less than the different makes of bearings and the way it was originally shimmed.
Is that really true? I would have expected bearing manufacturers to work to pretty tight, internationally recognised tolerances. Tighter tolerances than those used to make a motorbike final drive (hence the shims). But hey, what do I know....
Mick
livin' the dream
I'll mic up the old and new bearings and see.
