Final drive swop R100GS
Two wheels good
Bobbing up in Cork, IRL
Hi
Is there any reason why the final drive from an '88 Paralever shouldn't fit a '94 (paralever, obviously)
An unexpected MOT failure - play in the bevel drive (not pivot bearings) -prompts me to make an urgent swop in order to have the bike ready for a trip next week
(BTW no play apparent when the wheel was in the air but when on the ground the play was excessive)
Many thanks
David
PS No, I havent taken the wheel off yet for a closer look yet
Same final drive.
Only variation is between the ratio on the R80GS and R100GS
Thanks for response
As it turned out the problem was the pivot bearings. - my first suspicion though the MOT tester convinced me otherwise. Once the wheel was off it was obvious.
BTW
The Haynes manual quotes a torque of 150Nm for the fixed (left hand) pivot pin. What would that do to my swinging arm!! A K-series Clymer manual quotes approx 8Nm for the same thing
i think you've mixed up the instructions. this is the BMW manual:
As you gessed - 150 nM is wrong. Use yer head, if you were on the road using teh bikes original spanners - how much torque could you apply?
Paralever pivot torque settings
Sure, the Haynes manual is obviously wrong but even Cookies' BWM manual quotes 105Nm! That's the same as the wheel studs!
I settled on 40Nm and the specified Loctite
It's seen me to and from the Stella Alpina via many mountain cols so I think it's safe enough. Now I just need to investigate the slight miss that has developed..
David
