Deleted account 191119001
- Joined
- Aug 13, 2017
- Messages
- 12,798
- Reaction score
- 9
Yep copperslip or similar anti seize compound will do the trick, use a small paintbrush & ignition on / off to exercise the valve while you are doing the application
Copperslip is not as good mate, the heat problem, you need Nickel it is way better it with stands 1450 C but yep ignition on to move the flap around, to get the anti seize in all the nooks and crannies possible....
