Fluffy Twin Spark Running Cured?
ianran
Here and there
Having spent ages trying to turn a pigs ear into a silk purse I think i have got the problem of dodgy acceleration sorted (courtesy of SCRIMMINGERS:thumb) Having replaced all plugs filters and a coil stick its down to a dodgy low tension lead on to the right hand coil:blast:blast
Probably a design fault together with dodgy servicing. |Nearly wet myself when I| found this was integral to the main loom (the cost!!) but there is a fix kit, still not cheap at 50 squiderlies but hopefully this heap of s*ite may acually work proprerly. Will let you know.
Got any pics of the offending piece?
Sadly no but its the connector that clips into the stick coil, it has a dodgy connector in it that intermittantly breaks the connection and therefore drops one cylinder down to secondary plug.
I called down to Steve Scrimminger's today to have my throttle bodies re-bushed on a ride in, ride out basis. Top Man.
Is your bike the Graphite 1150 with an MRA screen that was parked there?
Mike
Mike
Thats the bike ( as i think of it in under-coat!!) Steve has been pulling his hair out on mine bless him but top bloke.
I was recently considering cleaning my injectors, in order to do this I needed a power connector that fits in order to make the injector live, rummaging in the garage a connector that appears to fit came from would you believe a Citroen Xantia reversing light switch connector, mine came with a good foot of wire attached, would that have fixed your wiring problem do you think?
Stewart
Stewart
Not sure, might have to try though if sodding BM take any longer to deliver this bit, for this price I would have expected helicoptor delivery:blast
Wahay !!!!!!!!!!!! bikes finished goes like a dream , soooooooo looking forward to giving it some stick (only where legal of course!!):beerjug::beerjug:
