ianran
you've never ridden through Glencoe on a 500/4 in the rain then, with a great light show under the tank as first one, then two and three plug leads and caps break down and leave you on an very heavy 125.
Or a Suzuki TS125 that required a plug change 5 mins after starting and needed the points reset before coming home from every rally - could do it by eye in the end.
Only happened once on the R75/6, but that was going up the M6 in a snow storm with cherry red header pipes.
The Montesa Cota coil packed in when I was offroad solo in the middle of the Mourne Mts, lucky the tracks were downhill to the main road and then a 3 mile hike in wellies to a phone to arrange a recovery.
Did have a Suzuki 750 kettle that always wanted to be a 250cc via being a 500 which got hydraulic lock and shattered a piston.
A 750 trident that through a pushrod chasing a commando and an rd400 that welded the top of a piston to its barrel!
