Courtesy of Sooty 09 -The manual says 765ml 0f SAE7.5 hydraulic fluid for the initial fill. Then with the spring removed and the spacer installed (with all air bubbles removed) the level from fork leg top to fluid with forks fully compressed is 60mm.
Try using the search function.
