Right, Doc,
As I’ve incurred the WOW, here’s a very quick few ideas that I knocked up in 30 minutes after being up all night.
What I would do.
One night in Annecy ,unless you want to sight see.
Then ride the RDGA as far as Jausiers
Stay at Villa Morelia TWO nights.
Then next day ride the SE RDGA loop with lunch or a stop at Halte 2000 and a stop in Roubion for a few pics.
Back to Villa Morelia for rosé and medals.
Next day ride the other bit of RDGA to Castellane, where you’ll be staying at least TWO nights.
Drop your gear off at Nouvel Hotel du Commerce then go to Antibes for lunch via the Route Napoleon.Then ride around the coast and back to Castellane via Draguignan and the sublime D955
Next day ride around the Gorge du Verdon including the Route des Cretes.Have lunch in Aiguines.
These routes aren’t to be used-I knocked them up very quickly but it gives you some more ideas.
Basically, as I’ve said more than once ,as have others, you need multiple min bases. If your in the French Alps, you HAVE to sample the RDGA and the Route Napoleon.
No idea where you are going after Castellane but I would go up the Route Napoleon, branch off to Die and then over the Col du Rousset…..
