Front Brake Lever Removal R1100GS
Namastebuzz
Stonehaven
Maybe I'm being a numpty.....
Got master cylinder rebuild kit for my '98 1100GS. Assume you remove the brake lever first. Undone all the relevant bolts and removed the pivot pin - which was easy enough.
Still can't get the lever out - is it obvious?
Thanks Mark
That's great! Just what I needed.
Actually got the lever out immediately after I'd posted but the link was really helpful for the rest.
Buzz
How much was the rebuild kit and where from??
Cheers in advance.
I've got to renovate my master cylinder due to a slight leak but some of the paint has wrinkled and is coming off too. Any suggestions on paint to use on the alloy?
