The two halfs of the front calipars are held together by 4 allen bolts.
Can they be safely replaced, has anyone done this?
Thanks.
Russ.
Thanks.
Russ.
remove/replace one at a time - no problem ?
boxer said:just that I'm sure I've read somewhere it was a no-no.
Jimb said:I think you need to be carefull when fitting stainless bolts to brakes, the materiel is not always up to the torque required for brakes, might be worth checking out.
Steve Chip said:Steptoe...
What's you warranty claim procedure?
Steptoe said:don't worry, the torque you'll be using to tighten brake calipers comes no where near the shear point of the stainless bolt .
Steptoe said:its good to torque
