motorbike Registered user Joined Jan 31, 2011 Messages 187 Reaction score 0 Location glasgow May 4, 2014 #1 any one out there know the torque for the front sprocket nut....what is the standard amount of teeth and is it difficult to change same ....cheers
JohnnyBoxer Well-known member UKGSer Subscriber Joined Jan 3, 2002 Messages 52,424 Reaction score 10,692 Location North Yorkshire May 4, 2014 #2 15t standard Easy to change, if you have a grasp of spannering Torque, can't remember though - 70-80 nM ish
IJGser Registered user Joined Jun 12, 2009 Messages 1,699 Reaction score 0 Location Nr Loughborough May 4, 2014 #3 15 t is standard but 16 t is much better for road use. Very easy to Change and I wouldn't worry about torque just go as tight a a normal size bar/spanner will allow. Oh and make sure the cup washer is the right way round!
motorbike Registered user Joined Jan 31, 2011 Messages 187 Reaction score 0 Location glasgow May 5, 2014 #4 Thanks ..read somewhere that you need to grease splines and locktight nut ...also can you recomend a good quality sprocket,again read that tourateck ones have worn out the shaft splines?....maybe reading to much info on a simple task
mhsnowy Well-known member UKGSer Subscriber Joined Aug 8, 2010 Messages 505 Reaction score 3 Location Hertfordshire, England May 5, 2014 #5 Does the shoulder of the sprocket go in towards the gearbox or out towards the nut?
JohnnyBoxer Well-known member UKGSer Subscriber Joined Jan 3, 2002 Messages 52,424 Reaction score 10,692 Location North Yorkshire May 6, 2014 #6 Always use a BMW or Talon one The others are sloppy on the shaft
IJGser Registered user Joined Jun 12, 2009 Messages 1,699 Reaction score 0 Location Nr Loughborough May 6, 2014 #7 mhsnowy said: Does the shoulder of the sprocket go in towards the gearbox or out towards the nut? Click to expand... Out towards the nut I believe, if you mean the side that's raised in the centre.
IJGser Registered user Joined Jun 12, 2009 Messages 1,699 Reaction score 0 Location Nr Loughborough May 6, 2014 #8 JohnnyBoxer said: sloppy on the shaft Click to expand... Ohh err missus
