Hi Speedyeel,
First off, thanks for the great explanation and the videos. It's a well of knowledge inspiring courage for truing my wheels.
I've done my front about 6 times by now. Getting as best about 0.65 lateral and 0.45 vertical, and always starting over after a few days thinking I could do better, fool
I started almost always with a much better truing start (0.35 lateral 0.25 vertical), but the torquing process pushes it to the final result.
I use a poor's man "truspoke" tool. A tyre thread deph gauge. They are so cheap compare to the cost of the real thing, specially if you consider importing fees. Actually I came to it long time before I learn about the Truespoke tool. My engieenring mind wanted a bit of a baby balnket before I started adjusting all th espokes for the fist time, so I took a measure of each spoke depth in the nipple as a way to have a reference to come back. Crazy, I know.
I bought my rim new in the box as an old stock from BMW dealer warehouse in Germany. Good price but even being new was out of true by 1.3-1.7 and the rim extrusion has a good dip. The well known and poor engineered weld seam. When I pointed it out ro them, they offer to take it back, but I though I could give it a try at truing it.
My method is a bit of a mixed one, I wanted a starting point, but soon I realized the measurement of the spokes was only getting me closer but not there all the way. So I take the average of the outers and inners for the left and the right and then I center the wheel on the disks. After that I start tightening the all the spokes a couple of times (1/4 then 1/8) and check for trueness after each complete round. So far so good. Then I start torquing them in pairs always using the star patern for opposite spokes (1-4, 5-9, 10-14,....) to 1Nm and check the runout, then 1.5Nm and check and so on until 4Nm with 0.5Nm increments. My trick is to go ascending in the first round and in the next round descending in the next one, this way the idea is that the opossite spokes in each star are getting tighted each time as the torque on each spoke affects the opposite one.
With this I mean: first 1Nm to pairs 1 to 20 , then 1.5Nm but starting at 20 instead and ending at 1, then 2Nm 1-20, after that 2.5Nm 20 to 1, and so on, checking in between.
The consequence is that each torquing/tightening round increases the runout by 0..05 or so, as not every spoke is turned for the target torque of that round. It takes time and one has the feeling that is getting a bit worse every time but within tolerance and kind of a good enough result. I'm tone deaf and the plinging thing does not work for me.
Still even in my case the 0.65mm of runout feels woobly when watching it at high spin speed. And I don't like the dipping point at the welded join. I wonder how it will feel when riding.
BTW the reason for all this trouble and costs is to have to sets of wheels, road and off.
And now, my
question to you and the rest of the forum:
In the R1200GS air-oil-cooled, mine is a 2009, the front wheel has the ABS sensor mounted between the left disk brake and the wheel hub. it's 1mm thick and makes the disks sit asymmetrically with respect of the hub center. (The right disk is mounted directly on the hub)
So my question is:
When centering the front wheel should I center it in between the disks or over the hub?
I have done it both ways, but my final one is centered between the disk.
It seems all other generations have a separate mounting bracket for the ABS sensor and therefore the center of the hub is also the midpoint between the disks. But not in this one.
Are the brake calipers symetrical or is the left one offset to the fork (by1mm to compensate)?
I know 1mm only means 0.5mm on each side if the wheel is centered the wrong way, but still, we go through a lot of pain to come to this point so I want to do right.
Thanks so much for "listening" and for your patience.
All the best from the west coast of Sweden, (we got lots so much snow these last days
Carlos
