2003 Twin Spark GS adventure...
Had occasional issues with non starting and no fuel pump priming noises...
Being ridden down the road and just spluttered a few times then Died.
Power at the oblong connector (12v) for approx 1 second on initial ignition turn on.
No fuel pump prime or noise.
Fuel pump replaced with used one from Sherlocks, fault remains the same ..
Old pump tested on 12v and works ok. Tested circuit from plug to pump and shows continuous circuit ...
Any suggestions as to probable cause, or what to test next ?
Hall sensor wiring ? Scratching head a little
Thanks in advance
Thanks in advance
