Mark Hooton
Cymarcbikeparts
Guys, can anyone express an opinion (funny or not) that I can consider?
I`ve fitted a full Akro system and yes, verily, the mid range seems greatly improved along with a bit more at top end (btw the `flappy thing` has remained fitted).
I do not have a power commander nor have I had the bike `remapped` - the blurb on the box says its an instant gain of power and it seems to be right!
I`ve also got a K&N filter - during my KH250 days simply putting on a K&N filter was deffo the right thing to do but would it be necessary on the 2010 R1200GSA DOHC engine?
I`m just a little concerned that by changing too much I might actually be going `backwards` what with all this canbus/ecu/black magic which are on the bikes nowadays?
Would the ecu realise that the airflow has significantly changed and then change the other perameters accordingly? Would fitting it make the engine run too lean? Would the ecu compensate?
All I want to do is make the bike go as fast as a Smackheads Giro but with all the technical gubbins on the bike I don`t want to be wasting my time.
Has any other brave Tosser out there had any experiance with this and would they be kind enough to share their wisdom with me?
Ta.
Ta.
