I have a worsening issue with changing gear from 1st to 2nd - it requires an excessively positive movement of the lever (to the point where it gets painful for my foot riding in London stop-start traffic, which I do regularly) and around 25% of the time only makes it as far as neutral. There's no problem then selecting 2nd from neutral. As of this week the change from 2nd to 1st is now also becoming 'sticky' (that's the best description I can give) as if I'm changing down through a slight obstruction. Selecting 1st at a standstill is slick and normal (so not a clutch issue), clutch action is normal at all times and changing between other gears is also normal.
Changing from 1st to 2nd is slightly easier (less force required) at higher revs than at low revs but results in neutral rather than 2nd more often than it does at lower revs. The problem seems to be worse when the bike is hot than when it's cold.
Gearbox has Castrol EPX 80W-90 oil (Motorworks' recommendation) changed 3k miles ago, level checked last week and spot on. I've removed the gear linkage, cleaned and re-lubed the joints and checked lever free movement without the linkage attached. 2003 bike with 39k miles. The problem has become apparent, and progressively worse, over the past few hundred miles.
Any suggestions for what might be causing this? I was thinking to drain the oil and see what falls out with it but anything else I could try at the same time? Different oil? I think I remember seeing a recommendation for a Halfords gearbox oil which I'd normally steer well clear of. I'm hoping I won't be looking at a gearbox rebuild
