Martyn B Well-known member UKGSer Subscriber Joined Feb 5, 2003 Messages 531 Reaction score 0 Location Wilts, England Apr 29, 2011 #1 Anyone know what size socket I need to remove the fastener securing the gear lever onto the spline?
Pukmeister Well-known member UKGSer Subscriber Joined Apr 17, 2005 Messages 21,350 Reaction score 9,047 Location Hampshire Apr 29, 2011 #2 It's an E-fit socket (female Torx) which can also be undone with a normal ring spanner, about 8mm IIRC.
Martyn B Well-known member UKGSer Subscriber Joined Feb 5, 2003 Messages 531 Reaction score 0 Location Wilts, England Apr 29, 2011 #3 Excellent! Pukmeister said: It's an E-fit socket (female Torx) which can also be undone with a normal ring spanner, about 8mm IIRC. Click to expand... Thanks Adam, I'll give the 8mm a crack to see if I can save having to buy the Torx.
Mr K Registered user Joined Nov 21, 2004 Messages 40,616 Reaction score 13 Location The North East Apr 29, 2011 #4 Martyn B said: Thanks Adam, I'll give the 8mm a crack to see if I can save having to buy the Torx. Click to expand... Replace it with a 5mm allen bolt, once it's off. It's the only tor-x of that size on the bike.
Martyn B Well-known member UKGSer Subscriber Joined Feb 5, 2003 Messages 531 Reaction score 0 Location Wilts, England Apr 29, 2011 #5 Interesting... The 8mm didn't fit my 2010 GSA - but digging around in the bottom of the tool box, I found something that did - a VERY old 1/4" AF ring spanner! Good advice to replace it though Mr K...
Pukmeister Well-known member UKGSer Subscriber Joined Apr 17, 2005 Messages 21,350 Reaction score 9,047 Location Hampshire Apr 29, 2011 #6 I remembered using a small ring spanner, sorry about the duff info I now recall after reading your post it was 1/4" AF. I just checked in the garage and the socket is an E8. Glad you got it sorted.
