Trophy Gear-lever adjustment.
Jondd21
Wales
I need to adjust ( lift up ) the gear lever on my Trophy model, which does not have the enduro pack.
In the riders manual it mentions the Enduro pack and 719 lever adjustment, both of which have a multi position screw.
Looking at my bike, it appears that there is a threaded rod with a locking nut at each end where the rod goes into a knuckle joint.
So, I am hoping for some guidance/confirmation that what I am about to do is correct .
I want to loosen both lock nuts and turn the rod until the lever lifts. My concern is….will this affect the auto blipper and will any electronic
re calibration be required ?
Or, putting it another way…has anyone adjusted one and how ?
Thanks in advance. 👍
Yes you can alter the rod length like you are suggesting and it won't affect the GSAP. Only thing to watch is that you don't get too close to the end of the threads on the rod so that it risks pulling out and stripping the threads when you change gear. One end of the rod is a lh thread & the other a rh thread , just bear that in mind when loosening the lock nuts.
