Gear position switch and neutral indicator
shready
Surrey
I've got an 1150GSA and the gear position indicator is playing up, showing the numbers incorrectly, especially 3rd and 4th. No big deal but I also get an occassional failure of the neutral light to show and on one occassion the bike wouldn't start in neutral but started with the clutch lever pulled in.
I plan to get the switch replaced at my next service but before then I have a trip to Spain, in the next 3 weeks for 10 days.
Am I correct in thinking that this switch isn't going to cause any starting failure or should it be replaced before I travel?
It's easy enough to dismantle & clean...
...once you have removed it from the bike. :green gri
No issues apart from those you have already experienced.
You can pick them up between £30-£50 second hand depending on model, and around £100 new.
Just means you have to count up too or down from 6, and use clutch in with sidestand up to restart if it goes.
Sent from my SM-G925F using Tapatalk
