My neutral light was illuminating for a while and decided to clean the Gear position indicator switch as i have y piece of bits which is relatively easy to reach to the Gear position indicator switch . last weekend i unplugged the switch using a tall screw driver then sprayed though out with gt85 and it was dirty though. i can say it helped to the neurtal light and have been easy to find since then HOWEVER i lost the 1st 2nd and 3rd gear of indicators on the dash.it only shows 4th gear (for 1,2,3) it was showing 4th,5th and 6th correctly . so i decided to spay with wd40 this weekend i thought that could cure the problem . this time i only have 4th gear showing on the dashboard for the all gears. Neutral light still easily and correctly can be found.
i searched on the forum but could not found anything close to my solution . it is mentioned that there are 3 small pins and spring inside the gear switch and to be careful when unplugging however i have not noticed those items . i hope that they did not come off .
does anyone know how to fix this ?
