1150 RT gear position indicator question
blues n twos
Seer Green, Bucks
Hi all,
Asking on behalf of a friend who has just purchased an 1150RT and his gear indicator on the dash is doing its own thing :blast
Just wondering if this is likely to be the switch on the shifter :nenau if so where is it? My mates not very tech savvy but his brother is :thumb2
Anything else he should consider :nenau
Pic below of his RT and his brothers mint LT :cool:
Jon
Back of gearbox, below and in front of swingarm
There are a couple of sticky out legs for the big "circlip" type thing that holds it in, you can grip them with a pair of long bent nose pliers (and cable tie it closed ;) ) and it can be got out with a bit of wiggling
The plug is up on the left side of the frame forward of the ABS unit
Thank you so much for the detailed reply :thumb2
I’ll forward this info on to him :beerjug:
All the best to you,
Jon
