Gears
Zoton
15mg and rising
Dinky Poo in Wales
Anybody had any experience with the gear change.
Earlier this year my 2001 gs started to stick in 2nd gear when changing up the box.The only way I could change gear again was
To slowdown, throttle off clutch fully in and give it a good boot at changing up this took 3 odd attempts.This happened several times over a few weeks.(the gear leaver would not budge)
I went back to Rydales and the fitter (technician) took it for a test ride and of course nothing happened.
They did suggest that it was my riding style : confused:
and to be fair offered to bring someone in from Bracknall ( ? )to take it for a ride if it continued.
As it has started to happening again ( seems to be that after a few short journeys that it starts again and after a long one stops ) I thought i'd post this.
I have not gone back to rydales yet nore have I had a crap servise from them but I'm fishing to see if anyone else has had problems same as mine.
:smokeboun
Take the gear shift arm off completely, clean the pivot thoroughly, regrease and reassemble. Also clean, grease and adjust the adjuster screw. That should solve things for you.
