Having nightmare bleeding abs system on my 2000 1150. Have been thinking about stripping all the abs gubbins out over this winter anyhow. What can of worms am i gonna open by ripping it all out and going to conventional brake system??? I will/would be buying the Goodridge non abs brake line kit. Getting fed up with having spongy brake lever! Any input greatfully received.
I would presevere though, removing the ABS would devalue the bike, and theres always the possibility that you could end up with spongy brakes afterwards too, the system is originally filled from the bottom upwards, and I think that is why I have had pretty good success pushing fluid in via the bleed nipple, I can actually see tiny bubbles popping out of the little port in the master cylinder as it fills, are you sure the master cylinder is okay? It might be worth substituting another just to try. Keep trying, you will get there, and the inside of your brakes will be spotless
